Enables the XNV feature on the specified ports.
port_list |
Specifies one or more ports or slots and ports. |
Disabled.
You must enable VM tracking on the switch with the enable vm-tracking command before you can use this command. This command enables VM tracking on the specified ports. You should enable VM tracking only on ports that connect directly to a server that hosts VMs that you want to track. You should never enable VM tracking on a switch uplink port.
The following command enables VM tracking on port 2:1:
# enable vm-tracking ports 2:1
This command was first available in ExtremeXOS 12.5.
This command is available on ExtremeSwitching 5420 and 5520 series switches.
